  • Peter Cort Larsen 421 posts 1038 karma points
    Oct 22, 2020 @ 10:49
    Peter Cort Larsen
    New installation models problem
    On a new umb 8.8 installation i use modelsbuilder LiveAppData.
    The models get generated in VS.
    On my template i have this (which is generated out of the box).
    The type 'Forside' is not valid. Cant i use strongly typed models?
    It says: The type or namespace name 'Forside' does not exist in the namespace 'Umbraco.Web.PublishedModels' (are you missing an assembly reference?)
    @using ContentModels = Umbraco.Web.PublishedModels;
    @{ Layout = "Master.cshtml"; }
    @Model.GoogleTagManager
  • Joep 96 posts 698 karma points
    Oct 22, 2020 @ 13:44
    Joep
    Did you include the generated models in your solution? And is 'Forside' the name of one of your doctypes?
    -Joep
  • Nicolai Christiansen 4 posts 96 karma points
    Oct 25, 2020 @ 20:43
    I had the same problem, and I included the Models folder under App_Data to my project, and now it works!
    Thanks Joep
    Oct 26, 2020 @ 07:13
    Peter Cort Larsen
    Yes I did
    Oct 22, 2020 @ 13:50
    Peter Cort Larsen
    I tried again, i think it might have been the .net version. First i used 4.8 then with 4.7.2 i got it to work
    Oct 26, 2020 @ 07:12
    Peter Cort Larsen
    Thanks Nico, sounds like an eas fix. I actually ended up using api models builder, which was my plan all along. Just wanted to try liveappdata also.
