I've followed your guide and added Umbraco Forms using the backoffice installer.
How should I reference the DLL:s correctly to be able to access things like
@Html.RenderUmbracoFormDependencies()and the Umbraco.Forms namespace in my backend? No references are added to the project when using the installer.
Reference Umbraco Forms assemblies
@Html.RenderUmbracoFormDependencies()and theUmbraco.Formsnamespace in my backend? No references are added to the project when using the installer.Hi Johan
The backoffice installer doesn't install visual studio project dependencies.
I recommend you to use Nuget for a such kind of installations if you work in Visual Studio.
Umbraco Forms Nuget - https://www.nuget.org/packages/UmbracoForms/
Alex
Alrighty, thanks for the clarification
