I can use the tag.Id in my url to push it to the tag logic, but from there it falls/ errors on the id since its suspecting a string due to:
var tags = Umbraco.TagQuery.GetAllContentTags().OrderBy(t => t.Text);
Note: The code itself works without any issues, same goes for fetching my tags, I wish to fix the w3c validation issues about the spaces.
Currently testing with replacing the space with an underscore '' by using .Replace(" ", "") on my regular page(s) and then on the tags page I convert the underscore '_' back to a space :)
Tags on site that have a space between words causes validation issues
I use the build in Umbraco tags on my site that have a space between words, e.g. "abc def".
This of course causes validators (W3C) to fall over the fact, the URL that would become: https://yoursite.com/tags?tag=abc def
How can I change this work with an ID instead of the tag Name? e.g. https://yoursite.com/tags?tag=123
I work with string tag = Request.QueryString["tag"]; to fetch the URL part starting after the '?'.
Current code: http://pastie.org/p/5Sy9W4eXSvv6XtOLW1PIGW
I can use the tag.Id in my url to push it to the tag logic, but from there it falls/ errors on the id since its suspecting a string due to: var tags = Umbraco.TagQuery.GetAllContentTags().OrderBy(t => t.Text);
Other suggestions are welcome, thanks!
I think I might have found a workaround.
Seems to be working.
