My project is suffering from intermittent 'The device is not ready' errors.
The Umbraco version 8.9.0 and the project is an upgraded version of this one https://github.com/anthonydotnet/ubase and it's running locally through IIS on my development machine.
I found a big thread where Azure was featured but this is not the case here.
at Umbraco.Core.Scoping.ScopeContext.ScopeExit(Boolean completed) in D:\a\1\s\src\Umbraco.Core\Scoping\ScopeContext.cs:line 38
at Umbraco.Core.Scoping.Scope.<>c__DisplayClass71_0.<RobustExit>b__2() in D:\a\1\s\src\Umbraco.Core\Scoping\Scope.cs:line 437
at Umbraco.Core.Scoping.Scope.TryFinally(Int32 index, Action[] actions) in D:\a\1\s\src\Umbraco.Core\Scoping\Scope.cs:line 472
at Umbraco.Core.Scoping.Scope.TryFinally(Int32 index, Action[] actions) in D:\a\1\s\src\Umbraco.Core\Scoping\Scope.cs:line 477
at Umbraco.Core.Scoping.Scope.RobustExit(Boolean completed, Boolean onException) in D:\a\1\s\src\Umbraco.Core\Scoping\Scope.cs:line 460
at Umbraco.Core.Scoping.Scope.Dispose() in D:\a\1\s\src\Umbraco.Core\Scoping\Scope.cs:line 365
at Umbraco.Core.Services.Implement.ContentService.SaveAndPublish(IContent content, String culture, Int32 userId, Boolean raiseEvents) in D:\a\1\s\src\Umbraco.Core\Services\Implement\ContentService.cs:line 909
at Umbraco.Web.Editors.ContentController.PublishInternal(ContentItemSave contentItem, String defaultCulture, String cultureForInvariantErrors, Boolean& wasCancelled, String[]& successfulCultures) in D:\a\1\s\src\Umbraco.Web\Editors\ContentController.cs:line 1257
at Umbraco.Web.Editors.ContentController.PostSaveInternal(ContentItemSave contentItem, Func`2 saveMethod, Func`2 mapToDisplay) in D:\a\1\s\src\Umbraco.Web\Editors\ContentController.cs:line 759
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters)
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count)
at CSharpTest.Net.IO.TransactedCompoundFile.fput(Int64 position, Byte[] bytes, Int32 offset, Int32 length)
at CSharpTest.Net.IO.TransactedCompoundFile.FileSection.Write(BlockRef block, FPut fput, Byte[] bytes, Int32 offset, Int32 length)
at CSharpTest.Net.IO.TransactedCompoundFile.Write(UInt32 handle, Byte[] bytes, Int32 offset, Int32 length)
at CSharpTest.Net.Storage.BTreeFileStoreV2.Update[T](IStorageHandle handleIn, ISerializer`1 serializer, T node)
at CSharpTest.Net.Collections.BPlusTree`2.StorageCache.OnItemRemoved(KeyValuePair`2 item)
at CSharpTest.Net.Collections.LurchTable`2.TryDequeue(Predicate`1 predicate, KeyValuePair`2& value)
at CSharpTest.Net.Collections.BPlusTree`2.StorageCache.Flush()
at CSharpTest.Net.Collections.BPlusTree`2.StorageCache.Commit()
at CSharpTest.Net.Collections.BPlusTree`2.CommitChanges(Boolean requiresLock)
at Umbraco.Web.PublishedCache.NuCache.ContentStore.Release(WriteLockInfo lockInfo, Boolean commit) in D:\a\1\s\src\Umbraco.Web\PublishedCache\NuCache\ContentStore.cs:line 196
at Umbraco.Core.Scoping.ScopeContext.ScopeExit(Boolean completed) in D:\a\1\s\src\Umbraco.Core\Scoping\ScopeContext.cs:line 26
Deleting the contents of
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\
and
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\
fixed the issue for me.
System.IO.IOException: The device is not ready
I had raised an issue on github (some extra info there) but it seems it may not be the fault of the Umbraco code https://github.com/umbraco/Umbraco-CMS/issues/9306
I've seen the error when trying to
Can anybody shed some light on how to fix this?
Thanks Matt
Today's error when publishing a content node:
Previously the errors have mentioned Lucene but not in the case of this one.
Deleting the contents of C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\ and C:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\ fixed the issue for me.
