  • Alexander 35 posts 85 karma points
    Nov 06, 2020 @ 03:45
    Alexander
    Umbraco upgrade 8.x to 8.9 using uSync.complete
    Hi everyone,
    I'm thinking about upgrading my umbraco version using uSync.complete. The plan is the following:
    1) Install a clean instance 8.9 2) Using usync publisher pull all the content/types/media from my existing dev environment. 3) Follow upgrade guides to upgrade the code base.
    Have anybody tried to do something like that? Any potential problems?
    Just curious to hear your opinion about that.
    Thanks, Alexander.
  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Nov 06, 2020 @ 09:24
    Kevin Jump
    Alex, there should be no problems doing that, but to be honest i would use, uSync & uSync.ContentEdtion, you don't need uSync.Complete to do the upgrade.
    If you export everything using the uSync dashboard - Then copy the uSync folder along with media, css, scripts and views folders - then when you start up your new site, you should be able to run a usync import and everything will be imported.
