"Distributed cache is not updated" on Azure single server (not load-balanced)
We are running Umbraco 7.15.5 in an Azure web app. It is just a single web app running in a single instance, so no load-balancing.
About once a week, I receive between 1 and 50 "Distributed cache is not updated" errors:
Message: DISTRIBUTED CACHE IS NOT UPDATED. Failed to execute instructions (id: 4932, instruction count: 1). Instruction is being skipped/ignored
Exception and stacktrace: System.NullReferenceException: Object reference not set to an instance of an object.
at Umbraco.Web.Cache.MediaCacheRefresher.ClearCache(JsonPayload[] payloads)
at Umbraco.Web.Cache.MediaCacheRefresher.Refresh(String jsonPayload)
at Umbraco.Core.Sync.DatabaseServerMessenger.NotifyRefreshers(IEnumerable1 instructions, HashSet1 processed)
at Umbraco.Core.Sync.DatabaseServerMessenger.ProcessDatabaseInstructions(IReadOnlyCollection1 instructionBatch, CacheInstructionDto dto, HashSet1 processed, Int32& lastId)
The site however is running just fine.
I have verified that distributedCall enable="false" is set in umbracoSettings.config.
Any tips for either fixing the error or getting rid of the warning?
I'm having the same error on a 7.15.7 site on a CD(www) node on a VM , where distribuedCall is DISABLED on the servers. One CD server works fine the other one doesn't seem to be updating its media cache and this is the only post with this particular error! Did you ever solve it?
Never mind I fixed my issue by rebuilding the InternalIndexer on the www node this sorted it. Strange as I thought media was in the ExternalIndexer but I suppose not!
Exception and stacktrace: System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Web.Cache.MediaCacheRefresher.ClearCache(JsonPayload[] payloads) at Umbraco.Web.Cache.MediaCacheRefresher.Refresh(String jsonPayload) at Umbraco.Core.Sync.DatabaseServerMessenger.NotifyRefreshers(IEnumerable
1 instructions, HashSet1 processed) at Umbraco.Core.Sync.DatabaseServerMessenger.ProcessDatabaseInstructions(IReadOnlyCollection1 instructionBatch, CacheInstructionDto dto, HashSet1 processed, Int32& lastId)The site however is running just fine.
