  • Mads 4 posts 74 karma points
    Nov 06, 2020 @ 13:29
    Mads
    Problem restoring from Cloud to Local
    Hi guys.
    I've tried to restore an environment from Cloud to a local solution before moving up to host.
    I followed the steps through the guide and are using vs studio code & IIS Express.
    When restore from cloud: It says: An error occured
    The source environment has thrown a System.Net.Http.HttpRequestException with message: An error while sending request. It might have been acaused by an inner System.Net.Socket.SocketException with message: An excisting connection was forcely closed by the remote host.
    I'm trying to restore from development environment.
    Hope you can help. Thanks in advance.
    /Mads
    Nov 10, 2020 @ 00:52
    Alex Skrypnyk
    Hi Mads
    Can you check the log? Maybe something there?
    Thanks, Alex
    Dec 03, 2020 @ 13:38
    Mads
    Hi Alex,
    Sorry for the late answer. I'm still facing the same problem when pushing restore button from localhost.
    Start of the log:
    Run :: initializing
    Run :: Is not running remote, Is not using Sql Azure.
    Run :: LocalDb is not available, using SqlCe.
  • Arun 144 posts 407 karma points
    Feb 02, 2021 @ 12:26
    Arun
    I have the same issue. Did you get any solution?
    Feb 04, 2021 @ 09:52
    Mads
    Hi Arun,
    Unfortunately I didn't managed to solve the issue. Consulted further help to solve the problem. Seemed like some extra packages issue, but out of my knowledge.
    Hope you will find a solution
