  • Rosie Holliday 4 posts 34 karma points
    Nov 10, 2020 @ 16:01
    Rosie Holliday
    Umbraco UDI to nodeid in SQL
    Hi all,
    I'm currently interrogating an Umbraco 8 SQL database for Power BI reasons.
    I am able to get so far with my query, however I am hitting a block where one of the properties is populated using a picker. The resulting column data is an Umbraco UDI (umb://document/stringifiedguid).
    Is there any way to turn this back in to a node ID without needing to use the Umbraco helper (getIdforUdi) in C# as this really needs to just be an SQL query.
    Thanks in advance for any help.
  • Joep 96 posts 698 karma points
    Nov 11, 2020 @ 15:58
    Joep
    DECLARE @uuid VARCHAR(50)
    set @uuid = PARSENAME(REPLACE('umb://document/stringifiedguid', '/', '.'), 1)
    select id from umbracoNode
    where uniqueId =CAST(
            SUBSTRING(@uuid, 1, 8) + '-' + SUBSTRING(@uuid, 9, 4) + '-' + SUBSTRING(@uuid, 13, 4) + '-' +
            SUBSTRING(@uuid, 17, 4) + '-' + SUBSTRING(@uuid, 21, 12)
            AS UNIQUEIDENTIFIER)
    This will select the Int node id. Just change the 'umb://document/stringifiedguid' to the real version and it should return the correct id.
    -Joep
    Nov 11, 2020 @ 16:00
    Rosie Holliday
    Brilliant! Thank you so much!!
    Nov 11, 2020 @ 16:10
    Rosie Holliday
    I wanted to add my own solution too, in case it helps anyone in the future
    SELECT id
        FROM umbracoNode
        where REPLACE(uniqueId, '-', '') =  REPLACE('umb://document/stringifiedguid', 'umb://document/', '')
