I want to add a second site to an existing Umbraco V8 instance. I can see the root the level nodes have an option for specifying domains but beyond that I can't figure out how to root those domains to the seperate sites. I've had a good look round and have been unable to find any tutorials or examples of how to set this up. Is there any guide on how to achieve this?
Once you point your additional domain to your instance just create a new root node (home 2 or whatever) right click > culture and hostnames > add your new domain and it should just work. Anything in particular you're having issues with?
Pointing two URLs to the same website is a good way to direct traffic to your site from several different domain names. You can accomplish this in two ways: either redirect one of the URLs to your primary domain https://testmyspeed.onl/, or create an alias for one of the URLs.
V8 Using multiple domains to point to seperate sites in the same instance
I expected it to be more complicated than that. That does indeed work. Thanks
