Is it possible to clear Development and Stage Environment and copy contents from Live in Umbraco Cloud?
I would like to replace Development and Stage with the contents in Live.
Is this possible?
I don't have time to clear error and sync these environments, so i need to clear existing items and make a copy of all contents from Live.
Does Umbraco allow that? Is there any solution?
maybe delete the non live env and then recreate them? That would create them back from live... and you don't need to mess with errors (not 100% sure so best check with cloud support)
First of all thanks for your very good question here. If you want to have everything from live on your dev and stage and do have time to clear out things now.
Then you can delete those environments and wait 5-10 min and re-create them.
Please be aware that you will get new GIT URLs for those environments. Also you will need to restore the content from live to stage and then from stage to dev
I would like to replace Development and Stage with the contents in Live. Is this possible?
Comment author was deleted
Hi Arun,
https://our.umbraco.com/documentation/Umbraco-Cloud/Deployment/Restoring-content/#restore-everything-through-the-umbraco-backoffice
All the best,
/Dennis
