Is this Runtime cache is at browser level or at server level ?
Example, I need to cache some api responses locally specific to user and can be used when ever required. I dont want to go with cookies as this will be displayed on browser.
Building on from David's answer, I was receiving errors about IAppPolicyCache not being available at runtime (v8). Here's how I needed to implement it:
using Umbraco.Core.Cache;
public class SomeService
private readonly IAppPolicyCache _cache;
public SomeService(AppCaches cache) {
_cache = cache.RuntimeCache;
public SomeObject GetItem() {
return _cache.GetCacheItem<SomeObject>("A_KEY");
public void SetItem(SomeObject obj) {
_cache.InsertCacheItem<SomeObject>("A_KEY", () => { return obj; }, new TimeSpan(10,0,0,0), true);
Umbraco 8 Runtime Cache and how to use it
Can anyone explain how I can use the Umbraco 8 Runtime cache. I would like to know how I can store an item in the runtime cache and retrieve it.
I've looked on the Umbraco docs but it only shows Umbraco 7, the internet seems to be sparse on information as well.
Any help (and code examples) will be greatly appreciated.
Hi Paul,
to use the RuntimeCache in v8 you can use the IAppPolicyCache interface and inject that in your classes.
Hope that helps to get you starting. :)
Thanks David, exactly what I needed.
Cheers
Any suggestions would be highly appreciated!
Thanks, Gurumurthy JV
This is server level cache.
IAppPolicyCachenot being available at runtime (v8). Here's how I needed to implement it:is working on a reply...
