When i try to roll back to a previously published version, it looks like its rolled back but the content stays the same. Is there a bug about roll back option?
Thank you
Once you have rolled back the content item to the version you want to go back to.
Then click away to another content item completely
Then click back to the content item that you have performed the roll back on, then does this now display the rolled back version? - If you save and publish this version is should update the published version of the page on the front end of the site.
(Essentially it's performing the rollback on the database, and I don't think it always updates the UI if you have the current version open on the screen! - and you need to publish to update the cache)
Roll Back Problem
Hello, When i try to roll back to a previously published version, it looks like its rolled back but the content stays the same. Is there a bug about roll back option? Thank you
Hi Kansu
regards
Marc
