I've installed usync console from
https://www.nuget.org/packages/uSync.Console
I am unable to export to a folder. I have tried
usync export ../temp
But get the following error message. Is my syntax incorrect?
the syntax is correct if you are running it directy from command line/powershel command e.g if you are in tehfolder for your site
c:\code\my-super-website\bin\>usync export [path]
but if you are inside the uSync 'console' so you typed 'usync' then this on the subsequent line, you can drop the first usync
usync
c:\code\my-super-website\bin>usync.exe usync>export [path]
Folder Import using uSync Console
usyncis working on a reply...
