  • Henrik 11 posts 61 karma points
    Dec 02, 2020 @ 19:01
    Henrik
    Problem rendering Multi-Url-Picker
    I am trying to render a Multi-Url-Picker using the standard Umbraco documentation at: https://our.umbraco.com/Documentation/Getting-Started/Backoffice/Property-Editors/Built-in-Property-Editors/Multi-Url-Picker/index-vpre8_8
    The datatype "secondaryNav" is placed on a "SiteSettings" page node in the content tree where i have my settings.
    Unfortunately i keep getting this error message. Since i am using code taken directly from the documentation it must be something about my "siteSettings"-setup that causes the problem but i cannot see what.
    My code:
        var siteSettings = root.SiblingsAndSelf().Where(x => x.ContentType.Alias == "siteSettings").First();
        var links = siteSettings.Value<IEnumerable<Link>>("secondaryNav");
         if (links.Any())
             foreach (var link in links)
                 <li><a href="@link.Url()" target="@link.Target">@link.Name</a></li>
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Dec 03, 2020 @ 08:08
    Steve Morgan
    link is a special model that has the following:
       public string Name { get; set; }
        public string Target { get; set; }
        public LinkType Type { get; set; }
        public Udi Udi { get; set; }
        public string Url { get; set; }
    So as you can see Url is a string here not a method you can call.. so just change
    to:
    <li><a href="@link.Url" target="@link.Target">@link.Name</a></li>
    Dec 03, 2020 @ 10:36
    Henrik
    Thanks so much. That fixed it.
  • Owain Williams 482 posts 1414 karma points MVP 8x c-trib
    Dec 03, 2020 @ 10:18
    Owain Williams
    This is my mistake - sorry, I updated the documents for this section yesterday and it is indeed incorrect.
    Thanks for highlighting this @Henrik
    Dec 03, 2020 @ 10:30
    Henrik
    No worries :)
