  • Kevin Meilander 82 posts 408 karma points MVP c-trib
    Dec 03, 2020 @ 15:33
    Kevin Meilander
    When to use Block List Settings
    Does any one have any guidelines for when to use the blocklist settings vs blocklist content?
    I'm having trouble wrapping my head around when I would use settings.
  • Marc Love (uSkinned.net) 447 posts 1790 karma points MVP
    Dec 03, 2020 @ 15:51
    Hi Kevin,
    We use 'Content' for anything that is actual content that gets displayed on the frontend. We use 'Settings' for values that alter the way the content is displayed. This might be background colours, text alignment, spacing etc.
    Hope that helps.
    Marc
  • Damien Holley 181 posts 542 karma points
    Dec 14, 2020 @ 22:15
    Damien Holley
    As different settings models may be used in different blocklists for the same block (or use the same one for multiple block types) my thoughts are that the conntent should be anything that is always required for that block.
    Settings are anything that relates to what it is held in (width, fill etc.)
  • Brendan Rice 538 posts 1102 karma points
    Dec 14, 2020 @ 22:31
    Brendan Rice
    I'm with Marc, content for data and settings for display.
    Dec 16, 2020 @ 01:14
    Damien Holley
    I like this idea, until I realised the block is completely decoupled from the settings so it has to be added to every single blocklist this block is used on.
    This makes it more of a item that relates the block to the blocklist rather than settings for the block itself, so I use it for block widths and other generic data that may affect the containing div rather than the internal workings.
  • Mark Drake 134 posts 458 karma points c-trib
    Dec 15, 2020 @ 03:36
    Mark Drake
    2
    I don't find it so easy to separate a block list editor from it's content and various settings and configuration.
    The block list editors I setup are usually user interface components like:
    • Breadcrumbs
    • HTML Block
    • Rich Text
    • Video
    • Horizontal Card
    • Vertical Cards
    • Banner
    • Slider
    • Carousel
    The settings are often times unique to the component. I didn't like doubling up on all of these element types, example:
    • SliderBlock
    • SliderBlockSettings
    I am considering a settings type for everything general - margins, padding, background [color or image], id attribute, html tag [div, section, article], and the such.
    But in general, my settings are too specific and thus are put in the element type.
    Dec 15, 2020 @ 23:15
    Damien Holley
    +1 to this, I am finding a LOT of settings that are component unique.
    That being said, there are the containner settings or generic settings that can be used (% width of container) which can be applied to a lot of blocks and may differ based on the blocklist the block is in.
