  • Jesper Ordrup 1019 posts 1528 karma points MVP
    Dec 04, 2020 @ 23:09
    Jesper Ordrup
    Using API to create users and send invite
    I'm sure it's possible but I can't find it in the Umbraco 8 API?
    /Jesper
    Dec 04, 2020 @ 23:16
    Huw Reddick
    you can create a user like this
            RegisterModel regModel = RegisterModel.CreateModel();
            regModel.Username = model.siemail;
            regModel.Email = model.siemail;
            regModel.Password = model.sipassword;
            regModel.Name = model.firstName + " " + model.lastName;
            MembershipCreateStatus regStatus = new MembershipCreateStatus();
            MembershipUser user = Members.RegisterMember(regModel, out regStatus, false);
            if (regStatus != MembershipCreateStatus.Success)
                throw new System.Exception("Unable to register user: " + regStatus);
    Dec 04, 2020 @ 23:42
    Jesper Ordrup
    Thank you. I might have approached this wrong. I just went to the docs that describes how to create user using userservice. That works too.
    My problem is that I can't find how to send the invite - your approach doesn't allow this either. Correct ?
    Dec 05, 2020 @ 08:04
    Huw Reddick
    at what stage do you want to send an invite? Do you want the invite to have some sort of validation link. If you could explain the flow that you require I can explain what you need to do.
    Our registration process involves an email confirmation step so it is quite straight forward to do.
    Dec 06, 2020 @ 12:53
    Jesper Ordrup
    Consider the flow in Umbraco UI where you in the usersection can either invite or create a user.
    I thought that the invite user feature was available via Api (send invitation and accept invitation)
