Render HTML data on frontend using custom property editor
Hello All
I want to create a plugin that fetch data from API and render it on frontend.
To achieve this, I created a custom property editor. My property editor is able to fetch data from API and rendering it on backoffice.
But when i try to render same on frontend, its do nothing.
Can anyone help me if it is possible to render HTML data from property editor to frontend or is their any other way to achieve same
Hello All
To achieve this, I created a custom property editor. My property editor is able to fetch data from API and rendering it on backoffice. But when i try to render same on frontend, its do nothing. Can anyone help me if it is possible to render HTML data from property editor to frontend or is their any other way to achieve same
Thanks you in advance
