  • Andrew Bright 71 posts 231 karma points
    Dec 10, 2020 @ 20:50
    Andrew Bright
    Related Links not including properties
    I am using Umbraco.RelatedLinks2 example grid below: enter image description here
    The first two links are internal pages the second of which is unpublished and the last two links are external. I firstly need to identify internal pages and exclude those that are unpublished to avoid 404 and secondly check external links are not null.
    backend code snippet:
     foreach (var item in Model.Content.GetPropertyValue<JArray>("relatedLinks", true))
        var nodeId = Model.Content.Parent.Children
        // Or you could use "InvariantEquals".
        .Where(x => x.Name.InvariantContains(item.Value<string>("caption")))
        .Select(x => x.Id).FirstOrDefault();
        var linkUrl = (item.Value<bool>("isInternal")) ? Umbraco.NiceUrl(item.Value<int>("internal")) : item.Value<string>("link");
        bool published = false;
        // Get the content parent and find the child using the related link caption as name lookup
        // return if the content is published (Visible)
        published = Model.Content.Parent.Children
        .Select(x => x.IsVisible()).FirstOrDefault();
    The isInternal is always returning false and subsequently no Id is being returned either and Im not sure why see json from JArray below:
        "caption": "Check when your bin will be emptied",
        "link": "/check-when-your-bin-will-be-emptied",
        "newWindow": false,
        "edit": false,
        "isInternal": false,
        "type": "external",
        "title": "Check when your bin will be emptied"
        "caption": "What goes in which bin",
        "link": "/what-goes-in-which-bin",
        "newWindow": false,
        "edit": false,
        "type": "external",
        "title": "What goes in which bin"
        "caption": "Testing external",
        "link": "http://testing.com",
        "newWindow": false,
        "edit": false,
        "type": "external",
        "title": "Testing external"
        "caption": "Testing",
        "link": "testingtwo.com",
        "newWindow": false,
        "edit": false,
        "type": "external",
        "title": "Testing"
    Please could someone advise on this please?
    Andrew
  • Amir Khan 1276 posts 2712 karma points
    Dec 10, 2020 @ 22:13
    Amir Khan
    Any reason not to use the property value converter link in the docs? https://our.umbraco.com/documentation/getting-started/backoffice/property-editors/built-in-property-editors/Related-Links2
    Should take care of most of those issues for you.
    Dec 10, 2020 @ 23:11
    Andrew Bright
    Thanks for the response but using :
    @if (Model.Content.RelatedLinks != null &&
    Model.Content.RelatedLinks.Count() > 0)
    var typedRelatedLinksConverted =
    Model.Content.GetPropertyValue<RelatedLinks>("relatedLinks");
    foreach (var item in typedRelatedLinksConverted)
        var linkUrl = (item.IsInternal) ? Umbraco.NiceUrl(nodeId) : item.Link;
    Proves to be no different I am afraid and this is including @using Umbraco.Web.Models
  • Carlos Mosqueda 239 posts 429 karma points
    May 04, 2021 @ 17:55
    Carlos Mosqueda
    Did you ever find a solution for this?
    GetPropertyValue
    But again, this is Umbraco 7, and they have moved onto 8 where they got rid of related links in favor of MutilUrl Picker.
    But if you have a solution or I find one, I would be more than happy to find out or have any help.
