  • Sven 34 posts 138 karma points
    Dec 11, 2020 @ 14:22
    Sven
    Examine query problem
    Hello !
    i'm running into some issues trying to create a Examine Query.
    In my custom index I have a field called 'TestTaxonomy' with for example the following value: umb://document/75e97ba7f01c4723a258a243bf813a1c,umb://document/e936faa0f0eb4c62aeb993de3351a1f4
    In this value I would like to be able to search 1 value and return the item if the value is found.
    My current query:
     var results = _newsIndexSearcher.CreateQuery(IndexTypes.Content, BooleanOperation.Or)
                .GroupedOr(new string[] { "TestTaxonomy_" + _currentCulture }, allThemesUdis.ToArray())
                .Not().Field("__nodeId", newsItemId)
                .OrderByDescending(new SortableField("createDate"))
                .Execute(4);
    This query works if my 'TestTaxonomy' field only has 1 value, however it goes wrong when there are more then 1 values.
    Examples in screenshot
    Thanks!enter image description here
    Dec 15, 2020 @ 07:19
    Sven
    Using .Fuzzy() was the solution for anyone wondering!
