  • lori ryan 239 posts 573 karma points
    Dec 15, 2020 @ 17:17
    lori ryan
    Encrypting the Umbraco Connection String - SQL Authentication
    I have been asked it is possible to encrypt the Umbraco connection string? The current project has to use SQL Authentication. Any thoughts? Any pointers or help would be most welcome
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Dec 15, 2020 @ 17:48
    Huw Reddick
    I gues that largely depends how Umbraco retreives the connection string, if it using standard .Net methods to do that then you can encrypt the connection strings section using aspnet_regiis.exe
    encrypt connection string
    Dec 15, 2020 @ 18:02
    lori ryan
    Thanks for coming back to me, is it possible to do it via code OR part of ci/cd (azure dev ops) rather than command window?
    Dec 15, 2020 @ 19:11
    Huw Reddick
    not sure as I think it has to be done on the server it is deployed on, but I will ask our devOps guy tomorrow for you
    Dec 18, 2020 @ 16:19
    Huw Reddick
    it would not be possible to do as part of devops build etc, however you may be able to do it in code by creating an encryption provider.
    Have a read of this Encrypting web.config sections
