  • V4A001 2 posts 22 karma points
    Dec 28, 2020 @ 15:52
    V4A001
    Multi language setting
    It is unclear how multilingual can be turned on so that I can see how functionality works. I am just looking if Umbraco could be useful on a demo version. I think that is Uno, but I do not see how to turn on
  • Amir Khan 1289 posts 2746 karma points
    Dec 28, 2020 @ 20:24
    Amir Khan
    Its not really an on / off switch and requires some setup but if you're using Umbraco V8 this will get you started: https://our.umbraco.com/documentation/Getting-Started/Backoffice/Variants/
    Dec 29, 2020 @ 09:17
    V4A001
    Thank you. To be more precise: I do not see the 'Settings' in the menu on the demo site I created on umbraco.io. The information box says it is version 'Umbraco version 8.7.1'.
    I suspect the demo (cloud hosted) site does not have this option?
  • Keown 13 posts 83 karma points
    Jan 01, 2021 @ 04:18
    Keown
    This is a survey setting that you can use to add one or more translations to your survey, instead of creating multiple surveys and handling the different languages separately.
