Umbraco 8 Examine programmatically re-index specific node
Hi All,
Does anyone know how to trigger a re-index on a specific node or node Id only?
I have an adding some fields into the search index (IndexProviderTransformingIndexValues) and I have an extra requirement where I need to trigger a re-index of a specific node (ONLY).
I know I could just re-publish that node to achieve the same thing but I don't really need to do that and create the unnecessary history etc.
The calculated field I have added into the index that I need to update/re-index is calculated based on data external to this specific node (but related) that's why I don't really need to re-publish but instead just need to update the value stored in the index related to this specific node.
If there is some way I can trigger the TransformingIndexValues event for a specific node without having to re-publish the node that would be awesome.
Hi All,
Thanks in advanced
Kind Regards
David
Did you manage to solve this?
Thank you.
No Sorry.
I probably just did a work around. I cant remember what I ended up doing.
