Does anyone know if it's possible to access the settings model from the label field ? (see the attached screendump)
Hi Sebastian,
Yes, this is possible however you will need to be running at least Umbraco 8.10.0
Syntax is: $settings.propertyAlias
Marc
Thanks. I'm at 8.9.0 so I need to upgrade
If anybody is curious, there is now a page that documents this: https://docs.umbraco.com/umbraco-cms/fundamentals/backoffice/property-editors/built-in-umbraco-property-editors/block-editor/label-property-configuration
Talks about things like $settings, as well as related concepts, such as: $contentTypeName, $index, and $layout.
$settings
$contentTypeName
$index
$layout
Block List Editor: Accessing Block Settings model from label field ?
Hi Sebastian,
Marc
$settings, as well as related concepts, such as:$contentTypeName,$index, and$layout.is working on a reply...
