  • Madeline Wilborn 1 post 71 karma points
    Jan 13, 2021 @ 07:22
    Madeline Wilborn
    Umbraco data problem
    I try to use the Umbraco 8 documentation but some things do not work for me. I took the following lines from the Umbraco documentation but the Content object does not exist:
    var site = Model.Content.Site();
    var doThis = Umbraco.TypedContent(123);
    I also tried to access the content directly from database but again I had the same result:
    var dontDoThis = ApplicationContext.Services.ContentService.GetById(123);
    Do I have to add a reference or a using in my view?
    Thanks in advance for your help.
    Jan 13, 2021 @ 10:51
    Alex Skrypnyk
    Hi Madeline
    You have to use real node ID in GetById method, can you check that you use the correct node ID there?
    Alex
  • Søren Kottal 713 posts 4571 karma points MVP 7x c-trib
    Jan 13, 2021 @ 11:24
    Søren Kottal
    Hi Madeline
    What documentation article did you find that in?
    In Umbraco 8 that would be
    var site = Model.Root();
    var doThis = Umbraco.Content(123);
