  • Vyacheslav 13 posts 113 karma points
    Jan 28, 2021 @ 13:17
    Vyacheslav
    How to check database connection in U8
    I realized simple healthcheck in my site. I need to know, is connection to database ok or not. For this I want to ping it. How to ping database from api controller code?
    Jan 28, 2021 @ 13:37
    Huw Reddick
    if your db connection is not correct umbraco will not work, you will get an error trying to access it, so if you are in umbraco then your dbis working.
    Jan 29, 2021 @ 09:19
    Vyacheslav
    It's not always true. When I stop Database and call /umbraco/api/keepalive/ping, it returns
       <Message>I'm alive!</Message>  <Success>true</Success>
    But I have to know the state of the database connection. Is there some controller that gives information on the state of the database?
    Jan 29, 2021 @ 12:56
    Huw Reddick
    a ping will only tell you if the server is up or not, not whether something running on the server is running.
    Did you try turning of the db and then trying to load umbraco? it won't load if the database is not active. So not sure what you are trying to achieve with your check and to what purpose?
    If your database is not live, you won't be able to load umbraco to check the database
    Jan 29, 2021 @ 11:18
    Vyacheslav
    I did this solution
            private int GetDataBaseCode()
                ConnectionState state;
                using (var scope = Current.ScopeProvider.CreateScope(autoComplete: true))
                    try
                        state = scope.Database.Connection.State;
                    catch
                        state = ConnectionState.Broken;
                return state == ConnectionState.Open ? 200 : 500;
  • Yakov Lebski 594 posts 2350 karma points
    Jan 29, 2021 @ 19:21
    Yakov Lebski
    101
    I think the best way to use IUmbracoDatabaseFactory
    private readonly IUmbracoDatabaseFactory _umbracoDatabaseFactory;
        public YOURController(IUmbracoDatabaseFactory umbracoDatabaseFactory)
            _umbracoDatabaseFactory = umbracoDatabaseFactory;
    _umbracoDatabaseFactory.CanConnect
