  • Jerome 10 posts 90 karma points
    Jan 29, 2021 @ 05:50
    Jerome
    How to create Visual Studio project template
    My current steps for a single project is to create a new Visual Studio solution, add required Umbraco version, configure parts of the site (maybe config, add some settings).
    Is there a way that I could do this once so when creating a new Visual Studio project the default config and settings I have previously setup are applied whilst creating the new project? Maybe like a custom Umbraco template for a particular version that I can create without having to redo everything for every new project?
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Jan 29, 2021 @ 07:55
    Nik
    Hey Jerome,
    You could look into dotnet new templating to create a baseline type thing. It's the approach that the Umbraco Packages team has taken with helping create templates for creating Umbraco Packages.
    You can see how we went about it here :-) https://github.com/umbraco/Package.Templates
    Cheers
    Nik
    Jan 29, 2021 @ 08:58
    Jerome
    Hey Nik
    Appreciate the link..... Is there a guide I can follow as I'm not sure what I'm doing and how I would resolve the issue I described? Once I add or to the solution in not sure what I need to do next?
    Thank you
    Feb 01, 2021 @ 12:18
    Jerome
    Anyone with any guidance on this? Tried Visual Studio template but that was partial success so if anyone has experience with that, it should too help.
    Thank you
