  • Josip 195 posts 662 karma points c-trib
    Feb 15, 2021 @ 15:19
    Josip
    Registering custom view engine
    I need help, how can I do this in Umbraco 8.
    I am following this tutorial for Umbraco 7 made by Kevin Giszewski.
    using Umbraco.Core;
    namespace MyNamespace
        public class RegisterViewEngine : ApplicationEventHandler
            protected override void ApplicationStarting(UmbracoApplicationBase umbracoApplication,
                ApplicationContext applicationContext)
                System.Web.Mvc.ViewEngines.Engines.Add(new MyViewEngine());
                base.ApplicationStarting(umbracoApplication, applicationContext);
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Feb 15, 2021 @ 16:52
    Nik
    Hi Josip,
    In order to access similar events in v8, I advise reading this section of the Umbraco documentation: https://our.umbraco.com/Documentation/Reference/Events/Application-Startup
    ApplicationEventHandler no longer exists and has been replaced by a new Dependency Injection based mechanism. The docs are really thorough so have a read and I'm sure you'll be able to crack it :-)
    Cheers
    Nik
  • Danny Summers 5 posts 74 karma points
    Jul 25, 2022 @ 11:31
    Danny Summers
    Did you ever figure this one out? Looking to solve the same problem in a V10 site.
  • Jannik Anker 48 posts 258 karma points c-trib
    Jul 27, 2022 @ 11:23
    Jannik Anker
    Hey Danny,
    You could try adding the view engine in Startup.cs -> ConfigureServices? I don't have a custom view engine to test if it works, though ;-)
    services.AddMvc()
            .AddViewOptions(options =>
                    options.ViewEngines.Add(new MyFancyViewEngine());
