  • Jack 11 posts 94 karma points notactivated
    Feb 17, 2021 @ 10:04
    Jack
    Using Azure Active Directory for Umbraco Cloud Admin logins
    Has anyone successfully setup Azure AD on a Umbraco Cloud project to handle the admin logins for a website?
    I'm following this guide:
    https://our.umbraco.com/Documentation/Reference/Security/authenticate-with-AD
    And not having any luck, when I try and login with any username and password after following the steps in the above guide I get the following error response from the PostLogin network request:
    "Message":"An error has occurred.","ExceptionMessage":"The server could not be contacted."
    I have also tried following the steps in this guide:
    https://shazwazza.com/post/configuring-azure-active-directory-login-with-umbraco/
    However installing the package UmbracoCms.IdentityExtensions.AzureActiveDirectory does not seem to generate the necessary files in AppCode folder (as the blog says it should generate a few classes) - I tried doing this in a standalone Umbraco project and it did create some files in AppStart so I'm guessing this is a cloud project issue.
    Cloud projects now have Umbraco ID as a login option, I spoke to someone at Umbraco support who helpfully told me I would need to delete the following dll in order to get Azure AD to work on cloud:
    Umbraco.Cloud.Identity.Cms.dll
    I have tried deleting this on my local copy of the project and it hasn't helped. I'm now totally stuck.
    Hoping someone out there knows what I am doing wrong! Thanks
    Full error:
    "Message":"An error has occurred.","ExceptionMessage":"The server could not be contacted.","ExceptionType":"System.DirectoryServices.AccountManagement.PrincipalServerDownException","StackTrace":"   at System.DirectoryServices.AccountManagement.PrincipalContext.ReadServerConfig(String serverName, ServerProperties& properties)\r\n   at System.DirectoryServices.AccountManagement.PrincipalContext.DoServerVerifyAndPropRetrieval()\r\n   at System.DirectoryServices.AccountManagement.PrincipalContext..ctor(ContextType contextType, String name, String container, ContextOptions options, String userName, String password)\r\n   at System.DirectoryServices.AccountManagement.PrincipalContext..ctor(ContextType contextType, String name)\r\n   at Umbraco.Web.Security.ActiveDirectoryBackOfficeUserPasswordChecker.CheckPasswordAsync(BackOfficeIdentityUser user, String password)\r\n   at Umbraco.Web.Security.BackOfficeUserManager`1.<CheckPasswordAsync>d__19.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at Umbraco.Web.Security.BackOfficeSignInManager.<PasswordSignInAsyncImpl>d__7.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at Umbraco.Web.Security.BackOfficeSignInManager.<PasswordSignInAsync>d__6.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at Umbraco.Web.Editors.AuthenticationController.<PostLogin>d__14.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Threading.Tasks.TaskHelpersExtensions.<CastToObject>d__1`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()\r\n   at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()","InnerException":{"Message":"An error has occurred.","ExceptionMessage":"The LDAP server is unavailable.","ExceptionType":"System.DirectoryServices.Protocols.LdapException","StackTrace":"   at System.DirectoryServices.Protocols.LdapConnection.Connect()\r\n   at System.DirectoryServices.Protocols.LdapConnection.SendRequestHelper(DirectoryRequest request, Int32& messageID)\r\n   at System.DirectoryServices.Protocols.LdapConnection.SendRequest(DirectoryRequest request, TimeSpan requestTimeout)\r\n   at System.DirectoryServices.Protocols.LdapConnection.SendRequest(DirectoryRequest request)\r\n   at System.DirectoryServices.AccountManagement.PrincipalContext.ReadServerConfig(String serverName, ServerProperties& properties)"}
