  • Thomsen 113 posts 336 karma points
    Feb 20, 2021 @ 23:47
    Thomsen
    Use Multi Url Picker in macro as a parameter
    Does anyone know how to add the Multi Url Picker to the available property editors when defining macro parameters?
    I found out how to add the RTE as a macro parameter reading this post here:
    https://our.umbraco.com/forum/templates-partial-views-and-macros/82089-tinymce-as-macro-parameter
    Does anyone have a similar guide or snippet for adding the Multi Url Picker - that would be highly appreciated :-)
    Kind regards.
  • Marc Goodson 2157 posts 14434 karma points MVP 9x c-trib
    Feb 21, 2021 @ 08:01
    Marc Goodson
    Hi Thomsen
    There was a bug with using the same trick to add a Multi Url Picker as a Macro Picker, which was pulled in to be fixed in v8.7 so if you are on an eariler version than 8.7 this won't work.
    But if you are greater than 8.7 - you can see an example on the PR that fixed the issue:
    https://github.com/umbraco/Umbraco-CMS/pull/8144
    Hope that's enough of a steer for you to get it working.
    regards
    Marc
    Feb 21, 2021 @ 12:25
    Thomsen
    Thank you Marc, I'm in the latest v8 so I will give it a try this evening 👍🏻
    Mar 08, 2021 @ 15:02
    Thomsen
    • Thank you Marc, the example in your link worked!
