In the documentation section titled "Setup Umbraco for a FIPS Compliant Server", you show some code that needs to be added to my project to allow is to run on a FIPS compliant machine.
1) what project are you talking about?
2) can a file be added to the 8.11.1 download to get it to run on a FIPS machine? What folder should the file be added to?
3) if the unmodified project cannot be used, can I compile the a new file into the Umbraco source code?
Need more help running on a FIPS-compliant machine
