  • SkyTheLine 33 posts 103 karma points
    Feb 24, 2021 @ 22:01
    SkyTheLine
    Blogs with Comment function
    Hi there
    How are Blog Items stored in Umbraco?
    If i could get the ID, it would be easy to hook up a Commentfunction based to the ID
    Couldn't found any docs about it. All are using Disqus.com or such things.
    Feb 26, 2021 @ 14:43
    Huw Reddick
    They are stored as content the same as other stuff in Umbraco.
    If you take a look at https://our.umbraco.com/packages/collaboration/mediawizards-forum/ (The code is available on github)
    It is not a blog, but you would follow the same process to add comments to a blog as the forum is doing, they are just called forums/posts rather than blogs but should use a similar pattern
