  • Lesley 107 posts 350 karma points
    Mar 01, 2021 @ 03:29
    Lesley
    How to register and connect to a stand-alone database via NPoco
    We are currently registering a stand-alone SQL Server database in our composer using
    composition.RegisterUnique(typeof(IDatabase), new Database("registerDSN"));
    However, we are getting connection errors:
    ExecuteReader requires an open and available Connection. The connection's current state is connecting.
    What is the correct way to register the connection for use with DI so that handles opening and closing connections correctly?
  • AddWeb Solution Pvt. Ltd 109 posts 360 karma points
    Mar 02, 2021 @ 07:06
    Before Executing any Sql Query make sure that your connection of Application with DataBase is Open Refer this link :- https://stackoverflow.com/questions/9705637/executereader-requires-an-open-and-available-connection-the-connections-curren
