I'm struggling with my custom field added to the external index. I've added a new field as an int.
using System;
using Examine;
using Examine.Providers;
using Umbraco.Core;
using Umbraco.Core.Composing;
namespace MyApp.Composing
public class ExamineComponent : IComponent
private readonly IExamineManager _examineManager;
public ExamineComponent(IExamineManager examineManager)
this._examineManager = examineManager;
public void Initialize()
var index = this.GetIndex();
CustomiseIndex(index);
index.TransformingIndexValues += this.IndexProviderSetIsDeceased;
public void Terminate()
index.TransformingIndexValues -= this.IndexProviderSetIsDeceased;
private BaseIndexProvider GetIndex()
if (!this._examineManager.TryGetIndex(Constants.UmbracoIndexes.ExternalIndexName, out var index))
throw new InvalidOperationException(
$"No index found by name {Constants.UmbracoIndexes.ExternalIndexName}");
if (!(index is BaseIndexProvider indexProvider))
throw new InvalidOperationException("Could not cast");
return indexProvider;
private static void CustomiseIndex(BaseIndexProvider index)
index.FieldDefinitionCollection.TryAdd(new FieldDefinition("isDeceasedFlag", FieldDefinitionTypes.Integer));
private void IndexProviderSetIsDeceased(object sender, IndexingItemEventArgs e)
var isDeceased = e.ValueSet.GetValue("isDeceased") as int?;
if (isDeceased.HasValue)
e.ValueSet.Add("isDeceasedFlag", isDeceased.Value == 1 ? 1 : 0);
However I keep getting this error at startup sometimes:
[InvalidOperationException: Could not perform a range query on the field isDeceasedFlag, it's value type is Examine.LuceneEngine.Indexing.FullTextType]
Examine.LuceneEngine.Search.<>c__DisplayClass12_0`1.<RangeQueryInternal>b__0() in C:\Users\Shannon\Documents\_Projects\Examine\Examine\src\Examine\LuceneEngine\Search\LuceneSearchQuery.cs:115
Examine.LuceneEngine.Search.LateBoundQuery.get_Wrapped() in C:\Users\Shannon\Documents\_Projects\Examine\Examine\src\Examine\LuceneEngine\Search\LateBoundQuery.cs:13
Examine.LuceneEngine.Search.LateBoundQuery.ExtractTerms(ISet`1 terms) in C:\Users\Shannon\Documents\_Projects\Examine\Examine\src\Examine\LuceneEngine\Search\LateBoundQuery.cs:37
Lucene.Net.Search.BooleanQuery.ExtractTerms(ISet`1 terms) in d:\Lucene.Net\FullRepo\trunk\src\core\Search\BooleanQuery.cs:504
Examine.LuceneEngine.LuceneSearchResults.DoSearch(Query query, IEnumerable`1 sortField, Int32 maxResults) in C:\Users\Shannon\Documents\_Projects\Examine\Examine\src\Examine\LuceneEngine\LuceneSearchResults.cs:60
Examine.LuceneEngine.Search.LuceneSearchQuery.Search(Int32 maxResults) in C:\Users\Shannon\Documents\_Projects\Examine\Examine\src\Examine\LuceneEngine\Search\LuceneSearchQuery.cs:159
Examine.LuceneEngine.Search.LuceneBooleanOperation.Execute(Int32 maxResults) in C:\Users\Shannon\Documents\_Projects\Examine\Examine\src\Examine\LuceneEngine\Search\LuceneBooleanOperation.cs:46
MyApp.Services.BaseSearchService`1.PagedResults(Int32 page, Int32 pageSize, IQueryExecutor executeQuery) in C:\dev\mfpa\MFPA\MFPA\Services\SearchService.cs:276
I could post my whole search code, but trust me it works (later). The crucial part is:
I may have found the answer to my own issue. I'll post it now and remove it later if the problem reoccurs.
I didn't post my entire code before to keep the post concise. There are in face other TransformingIndexValues event handlers. The culprit being:
private void IndexProviderSetOnlyVisible(object sender, IndexingItemEventArgs e)
var hide = e.ValueSet.GetValue(Constants.Conventions.Content.NaviHide) as int?;
if (hide == 1)
e.Cancel = true;
This was my attempt to remove nodes from the index which should be hidden. I'm not clear why this logic is flawed, but I suspect it cancels more than the index of an individual node index.
I'm replacing that with specifying the value in the query
Examine field definition problems
However when I re-publish the nodes in question, and reboot the app, then we're all good again.
There's nothing relevant that I can see in the error log on boots which result in this error.
Any help or ideas are appreciate.
TransformingIndexValuesevent handlers. The culprit being:This was my attempt to remove nodes from the index which should be hidden. I'm not clear why this logic is flawed, but I suspect it cancels more than the index of an individual node index.
