Hello, on several of our productions sites I've noticed that there seem to be blueprints of element types but I don't know who or what creates them.
For example in umbraco v 8.10.1
The 'Content Page' template 'advies basis' was created by our customer. This is a document type in the content tree.
The templates 'Content Image' and 'Rich Text Editor' are element types we use in the grid editor. The name seems generated and the customer did not create these.
It is very confusing in the grid to add a component and you need to select a template.
What could cause these blueprint to be created? Can this be disabled?
So I was about to suggest it might be worth raising this issue with the package developer, and then I saw in the list of the issues on the git repo for the plugin:
So it looks like somebody else is experiencng the same issue!
So I'd add your voice to that issue, and follow along to see what the resolution there is.
It seems DTGE uses blueprints temporarily todo validation of the element when saving an item... and I suspect it's not cleaning up this temporary blueprint once it's done...
Grid auto generated blueprints of element type
Many thanks in advance.
Hi Billy
The additional content templates you are seeing on elements, all start with dtge and as you've spotted some 'generated' id
dtge is short for Doc Type Grid Editor
which is an additional package that can be installed in Umbraco to add a quick way to create strucuted grid editors for the grid.
I can see in version 1.0.0 the first proper release on V8, support for using Content Templates/Blueprints with the Doc Type Grid Elements was added:
https://github.com/skttl/umbraco-doc-type-grid-editor/releases
https://github.com/skttl/umbraco-doc-type-grid-editor/issues/241
https://github.com/skttl/umbraco-doc-type-grid-editor/blob/54c8d5a181728a0e2b7652591ff43dc03913b1a1/src/Our.Umbraco.DocTypeGridEditor/Web/UI/App_Plugins/DocTypeGridEditor/Js/doctypegrideditor.controllers.js#L256
The cleanup method perhaps not being called...
regards
marc
Hi Marc. Thanks alot for your answer. I'll have a look at the issue :)
