Everything seems to work fine, for a while, until it doesn't...
Upon visiting the Examine Management tab, we're presented with an error. Checking the logs and I can see the following:
System.IO.FileNotFoundException: _2i.fnm ---> System.IO.FileNotFoundException: Could not find file '\\xxxxxx\App_Data\TEMP\ExamineIndexes\External\_2i.fnm'. File name: '\\xxxxxx\App_Data\TEMP\ExamineIndexes\External\_2i.fnm'
The site is then in an unresponsive state and requires a restart, as well as clearing the Temp and Cache files. Although that doesn't always fix the corrupt Examine Index issue we seem to be having.
I've read and read Q&A's on the forums but it's all very confusing, so I was hoping someone would be able to point out our error.
Load Balancing Setup Issues
We currently have a load-balanced website with its files located on a centralised file share (Azure).
We have added the following to the web.config:
Thanks in advance.
you should define TempEnvDirectoryFactory for scale envriroment
<add key="Umbraco.Examine.LuceneDirectoryFactory" value="Examine.LuceneEngine.Directories.TempEnvDirectoryFactory, Examine" />Thanks, but we already have that in the web.config (as per my above query).
Did you ever figure out what is causing this? I'm seeing similar errors popup in my logging, even though it does not necessarily crash the server.
