  • Mehrdad Kamelzadeh 2 posts 72 karma points
    Mar 16, 2021 @ 00:57
    Mehrdad Kamelzadeh
    Load first child of a parent node
    This is the structure of my website
    Home
    =>Section1
    ==>article1
    ==>article2
    =>Section2
    ==>article3
    ==>article4
    The menu items are generated based on the section pages. For example, in this case I have two menu items "Section1" and "Section2"
    Each section has side navigation as well. In a way that clicking on item1 will navigate to /section1/article1
    This is my Section template:
    <div
        <aside>
            @{ foreach (var mainSection in homePage.Descendants<MainSection>())
                    <a href="@mainSection.Url()">@mainSection.Name</a>
                    foreach (var article in mainSection.Descendants<Article>())
                        <a href="@article.Url()">@article.Title</a>
                        currentArticle = article;
        </aside>
        @RenderSection("ArticleContent", false);
    The problem is when I click on section1, it throws an exception as cannot be requested directly because it calls the "RenderSection" method which makes sense from Razor's point of view but I don't know what would be my options.
    Objective: whenever a user clicks on the "Section1" menu item, it should be redirected to the first page under this section (i.e. /section1/article1).
    Any ideas would be appreciated.
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Mar 17, 2021 @ 07:25
    Huw Reddick
    Am I correct in assuming that you wish to make this link
    open the section 1 for that mainsection? If yes then you can do
    var firstArticle = mainSection.Descendants<Article>().FirstOrDefault();
    <a href="@firstArticle.Url()">@mainSection.Name</a>
