  • Billy 55 posts 266 karma points c-trib
    Mar 26, 2021 @ 10:10
    Billy
    Nested content not showing inherited/composed fields
    I created a document type 'Button Component'. This document type has 1 field. 3 other document types inherit this 'Button Component'.
    This inheritance works fine, for example in the 'Link Button':
    But when I'm creating nested content; the inherited field is not visible:
    Does nested content now show these inherited fields? I also tried adding the 'Size' using composition on my 3 document types but this also does not work.
    Any advice is welcome!
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Mar 26, 2021 @ 10:18
    Nik
    Hi Billy,
    Nested content will only ever show 1 property group. In order for you to get your inherited properties to show, you will need to make sure they are all in the same property group by changing the name on your "Button Component" group and ensuring the sort order is the same number as well.
    Nik
    Mar 26, 2021 @ 10:24
    Billy
    Okay I see. Thanks for the quick reply Nik!
