I'm using VS 2019 with Umbraco and Models builder enabled. My problem is that, when I create a new document type in Umbraco and try to access a page with that document type I get CS0234: The type or namespace name 'xxxx' does not exist in the namespace 'Umbraco.Web.PublishedModels' (are you missing an assembly reference?)
to solve this I have to stop visual studio, add the newly generated cs file in models folder to visual studio project and restart debugging. This is very time consuming. I think I'm doing something wrong here. Is there another way?
I think it worked on the fly in the past but nowadays you have to rebuild the dll containing the published models in LiveAppModel.
What you still can do on a live website when republicing is not a an option is instead of.
@Model.AboutText -> this will generate the error if the model dll isn't rebuild in the way you explained
@Model.Value("AboutText") -> this will work before the model dll is rebuild
Of course the later isn't a great coding practice so as soon as your able to rebuild and republisch the dll which contains the model also switch back to strongly typed code in the razor view like @Model.AboutText
Modelsbuilder with Visual Studio Problem
the modelsmode is LiveAppData
Thanks, Bora
I had the same question, see here -> https://our.umbraco.com/forum/using-umbraco-and-getting-started/105398-liveappmodel-working-different-then-expected
