  • Nathan Reece 62 posts 376 karma points
    Apr 14, 2021 @ 02:37
    Nathan Reece
    Umbraco 7 How to read dropdown values
    How do I read dropdown values of a data type in Umbraco 7?
    Can anyone help me out!!
    thanks in advance
  • David Armitage 510 posts 2082 karma points
    Apr 14, 2021 @ 03:20
    David Armitage
    Hi Nathan,
    This come should help you.
    The ID would be the ID of the data type within Umbraco. To find this you will have to go into the data types section within Umbraco backend and click on the dropdown field. The ID can be seen in the edit url.
    @using Umbraco.Core;
    @using Umbraco.Core.Services;
       IDataTypeService dataTypeService = ApplicationContext.Services.DataTypeService;
       var prevalues = dataTypeService.GetPreValuesByDataTypeId(14950);
    Kind Regards
    David
    Apr 14, 2021 @ 10:21
    Alex Skrypnyk
    To read just one prevalue value you can use this method:
    var prevalue = Umbraco.GetPreValueAsString(id);
    Where id is prevalueId.
    Alex
