  • AnandBhopale 54 posts 172 karma points
    Apr 20, 2021 @ 08:35
    AnandBhopale
    Angular Material UI with Umbraco
    I have requirement to develop complex form with Umbraco forms and looking for some guidance.
    Requirements
    1. Combo box with Data from custom Web API
    2. Date selector : multiple dates should be selected 3, Combo box with option to fill in the data
    3. Numeric Input box
    4. Address look up
    Is there any way to develop these as custom field type using angular material ? which version of Angular is supported by Umbraco 8 is there any example of using Angular Material within Umbraco.
    Apr 20, 2021 @ 09:22
    Alex Skrypnyk
    You can use Angular Material with Umbraco forms. I used Angular Material even in the backoffice. If you need to add custom fields it will work for sure.
    Thanks, Alex
  • Midhun Madhu 1 post 71 karma points
    Sep 18, 2024 @ 13:53
    Midhun Madhu
    Hi Alex,
    Could you please provide guidance on integrating Angular Material with the Umbraco backoffice for versions 13 and below?
    I'm currently facing challenges, and I'm stuck at this step: from forum
    Thanks!
    Apr 20, 2021 @ 10:32
    AnandBhopale
    Thank Alex.
    Do you any sample which I can refer to.
    Also, what is integration process with Umbraco Forms.
    Apr 20, 2021 @ 10:34
    Alex Skrypnyk
    You have to create custom fields, check out more here - https://our.umbraco.com/documentation/Add-ons/umbracoforms/developer/extending/adding-a-fieldtype
    Another way is to build a custom theme to control all forms code, check out more info here - https://our.umbraco.com/documentation/Add-ons/umbracoforms/developer/custom-markup/
