  • AnandBhopale 54 posts 172 karma points
    Apr 22, 2021 @ 13:48
    AnandBhopale
    Possible use of umbDateTimePicker control under Custom Field Type for Umbraco Forms
    I am trying to develop Custom Field Type for Umbraco Forms. While reading few questions on forum, I came across umb-date-time-picker control. I want similar control to be available for end user to select dates.
    Questions
    • Is the good idea to include umb-date-time-picker control under
     Umbraco forms ?
    • If not what is alternative ?
    • I am getting "angular not define" if I am integrating markup and controller on custom field cshtml page? So, angular.controller ("umbraco") will only work    under backoffice UI ? Do I need to refer my angular JS as separate file in fieldtype.*.cshtml
    Apr 23, 2021 @ 17:28
    Alex Skrypnyk
    Hi Anand
    Am I right that you want to use Umbraco forms DatePicker from the backoffice on the front end of the site?
    It's not possible to use Umbraco directives on the front. Try to use jquery UI datepicker or some other.
    What JS framework do you use?
    Alex
    Apr 27, 2021 @ 12:05
    AnandBhopale
    Thanks Alex.
    I understood that I cannot use backoffice directoring to render fields on Front-end (is it possible to use this in future ?).
    I am using Pikaday library for date range control.
    Apr 27, 2021 @ 19:52
    Alex Skrypnyk
    I think it will not be possible to use in the future. They are for backoffice
