In that case, I've been searching around for an example where i have a HTML and AngularJS page within the app_plugins folder. It loads as expected and shows the HTML page as per the link.
If i wanted to carry out some codebehind operation such as getting some value from a database or read a config file (which i would use C# for) how would i go about achieving the same?
I initially got an error which was resolved by logging in.
I then got an error 'The requested resource does not support http method 'GET''
I surrounded it with [HttpGet]
Now i get HTTP/1.1 417 Missing token
To really narrow this down i decided to create a simple method as below
[HttpGet]
public string SayHello()
return "Hello World";
That too gives the same 417 error. I cleared my cache/history but the same error.
Yes i have seen that thread and nothing really worked on what was mentioned.
Here is the code in a new class library and what im doing. Ive read the threads so have upgraded to Umbraco 7.5 where i feel most bugs were ironed out (Essentially a fresh copy of this install).
using System.Web.Http;
using Umbraco.Web.Editors;
namespace Test
[Umbraco.Web.Mvc.PluginController("Notes")]
public class HelloController : UmbracoAuthorizedJsonController
[HttpGet]
At first i got authentication denied but after logging in that error went away and several attempts later i either see ERRCONNECTIONREFUSED in Chrome or in Fiddler i see
The connection to 'localhost' failed. Error: ConnectionRefused (0x274d). System.Net.Sockets.SocketException No connection could be made because the target machine actively refused it 127.0.0.1:80
Just working on that error but as soon as Fiddler is closed i see the above
Custom Section using cshtml?
I have created a custom section using this article as a guide
https://www.enkelmedia.se/blogg/2013/11/22/creating-custom-sections-in-umbraco-7-part-1/
Is it possible for me to use cshtml files instead of HTML/Angular? If so can anyone provide me with any guide?
This isn't possible J. The back office is built on AngularJS and doesn't support cshtml.
@Brendan - Thank you
You will need to do either a post or get using is and call the method in your controller
Oh....any examples you could lead me to so i get an idea of what/where im doing all this? Thx
Here's a link to the docs that might be useful:
https://our.umbraco.com/Documentation/Tutorials/Creating-a-Property-Editor/part-4
Thanks, im working my way through and have hit a snag.
When i visit
localhost:1234/umbraco/backoffice/My/PersonApi/GetAll
I initially got an error which was resolved by logging in. I then got an error 'The requested resource does not support http method 'GET'' I surrounded it with [HttpGet]
Am i missing something?
Here is a thread with a similar issue:
https://our.umbraco.com/forum/umbraco-7/using-umbraco-7/60627-417-Missing-token-in-the-backoffice
My URL is
http://localhost/umbraco/backoffice/notes/hello/sayhello
I will leave the above code as is but what got it working was changing
to
UmbracoAuthorizedApiController
Hopefully this is the correct way!!??
Glad you got it working
