  • Carlos Mosqueda 239 posts 429 karma points
    May 07, 2021 @ 01:23
    Carlos Mosqueda
    Upgrade from Umbraco 7.12.1 to 7.15.7 - MultiUrlPicker issue
    I upgraded from 7.12.1 to 7.15.7 to get the MultiUrlPicker built into Umbraco.
    I updated the DLLs, the web.config and the umbracoSettings.config.
    I also updated the whole Umbraco and UmbracoClient folders on the server.
    When I went to use the Umbraco.MultiUrlPicker I connected it all up with the DocType, I go into the Content editor and try to do the "Add" it redirects me to the admin home and the url just hashes to "mydomain.com/umbraco/#/". I looked in the browser console and am getting
        Umbraco.PropertyEditors.MultiUrlPickerController' is not a function, got undefined
    I verified the new propertyeditor folder for the MUP is there because I did a replace of the Umbraco and the UmbracoClient folders.
    I also did the ClientDependency.config version update.
    Under my property it looks like the Angular is not getting the value I have ocnfigured in the property set up. It is ouputting under the property in the Content editor:
    "You need to add at least {{model.config.minNumber}} items You can only have {{model.config.maxNumber}} items selected"
    Are there any other files I need to update or replace in the file system?
  • Erik Eelman 79 posts 313 karma points
    May 07, 2021 @ 09:31
    Erik Eelman
    Hi Carlos,
    You could try changing the ClientDependency number to clear the cache. Here is a blogpost about how to diagnose umbraco upgrade issues
    May 07, 2021 @ 16:22
    Carlos Mosqueda
    Hi Erik,
    I did that already, with the client dependencies, but of course, Chrome held onto it like a vice grip. (Hand to forehead [wait don't touch your face.... J/K]). But yeh, Hard reload with Chrome coupled with the Client Dependency issue, brought it back to life.
    Thank you.
