  • AnandBhopale 54 posts 172 karma points
    May 12, 2021 @ 11:45
    AnandBhopale
    Problem loading with Identity Provider
    Hi Expert,
    I have set-up backoffice and member login using solution given at
    https://github.com/umbraco/UmbracoIdentityExtensions
    both solutions are working correctly individually. But I am not able to combine them in single project.
    ClassA has extended using UmbracoDefaultOwinStartup ClassB has extended using UmbracoIdentityOwinStartupBase
    Web.config has following
    When I am running project only Class B is getting executed.
    Is there any way to load both classes at Startup ?
