  • Thomas 319 posts 606 karma points c-trib
    May 18, 2021 @ 12:12
    Thomas
    HTTP site hosted behind HTTPS proxy not using correct protocol when loading avatars and fonts
    Our web site is hosted behind a proxy server which holds the sites SSL certificate.
    So the site sits native in HTTP, but the outside world sees it as HTTPS because of the proxy.
    We have some issue that some stuff from Umbraco are called with http and some with https.
    Ex. The user avatar image And the fonts on the frontend that are loaded with an relative path to the fonts
    Any one knows how to get around that ?? enter image description here enter image description here
    <add key="Umbraco.Core.UseHttps" value="false" /> is added in the webconfig
  • Brendan Rice 538 posts 1102 karma points
    May 18, 2021 @ 12:24
    Brendan Rice
    Hi Thomas,
    how is the font being referenced in the template/css?
    May 18, 2021 @ 12:44
    Thomas
    Hi Brendan,
    They are referenced like this. enter image description here
    It is not possible to add an absolute path because we are using the same css for other projects.
  • Erik Eelman 81 posts 321 karma points
    May 18, 2021 @ 13:57
    Erik Eelman
    Hi Thomas,
    You can try to force umbraco to use https for all backoffice calls with this config setting:
    <add key="Umbraco.Core.UseHttps" value="true" />
    More information about this: https://our.umbraco.com/documentation/reference/security/use-https
    May 18, 2021 @ 14:03
    Thomas
    Hi Erik,
    We all ready has that added.. Still not working..
    May 18, 2021 @ 14:04
    Thomas
    Sorry that part was not showed in my question..
    May 18, 2021 @ 14:12
    Erik Eelman
    Hi Thomas,
    Did you try to put the complete url including https:// to the website node in the umbraco backend under "Culture and hostnames"?
    If that doesn't work you could also add a rewrite rule to your web.config to force https
    <rule name="Force HTTPS" stopProcessing="true" enabled="true">
          <match url=".*" />
          <conditions logicalGrouping="MatchAll" trackAllCaptures="false">
            <add input="{HTTPS}" pattern="off" ignoreCase="true" />
          </conditions>
          <action type="Redirect" url="https://{HTTP_HOST}{REQUEST_URI}" redirectType="Permanent" />
        </rule>
  • Søren Gregersen 441 posts 1884 karma points MVP 2x c-trib
    May 18, 2021 @ 14:24
    Søren Gregersen
    this will cause the site to issue a redirect, but since it is behind a proxy, the condition will allways be true, resulting in a redirect loop.
    May 19, 2021 @ 07:21
    Thomas
    Hi Erik,
    This didn't do it..
    May 18, 2021 @ 14:26
    Søren Gregersen
    Hi Thomas,
    Are you able to rewrite the output in the proxy, to override "http:" with "https:"?
    Othervise you would need to make sure that all url's are implemented as https yourself in the html output from your site.
    May 19, 2021 @ 07:19
    Thomas
    Hi Søren
    Not sure if I can do that, will talk to our server hosting about that.
    It's not possible to make absolute paths that the domain url changes throug projects, but it's the same baseline code they are using.
