  • Johnny 3 posts 72 karma points
    May 20, 2021 @ 07:59
    Johnny
    How to use Swedish for Umbraco Forms?
    What is the correct way to have Forms fully in Swedish? The developer I use don't seem to be able to get Forms to be in Swedish. The rest of Umbraco is mostly Swedish. But new Forms created are all in english = annoying having to translate the forms every time to Swedish.
  • Nik 1616 posts 7262 karma points MVP 7x c-trib
    May 20, 2021 @ 09:06
    Nik
    Hi Johnny,
    I believe you can use Dictionary items to define captions/labels etc for your forms. Then you would set the language text in said dictionary items.
    Although I've not done this myself there are help docs on how to achieve it here: https://our.umbraco.com/documentation/Add-ons/umbracoforms/developer/Magic-Strings/
    I'm sharing this link to a previous bug around it for reference, but the bug was fixed in a more recent version: https://github.com/umbraco/Umbraco.Forms.Issues/issues/306
    Nik
    May 20, 2021 @ 12:16
    Johnny
    Thank you for your reply.
    Under Dictionary it says: "There are no dictionary items."
    Is it up to the developer to somehow connect Forms with the ability to translate via this interface?
