Dear all,
I have integrated the backoffice with Azure Active Directory as per guidance given in article.
https://shazwazza.com/post/configuring-azure-active-directory-login-with-umbraco/
I have following code in ADAuthExtension
public static void ConfigureBackOfficeAzureActiveDirectoryAuth(this IAppBuilder app, string tenant, string clientId, string postLoginRedirectUri, Guid issuerId, string strAuthenticationType , string caption = "Backend Login", string style = "btn-microsoft", string icon = "fa-windows") { var authority = string.Format(CultureInfo.InvariantCulture,"https://login.windows.net/{0}", tenant); string validate = app.GetDefaultSignInAsAuthenticationType(); var adOptionsBackend = new OpenIdConnectAuthenticationOptions("LBCBackEndAuthentication") { AuthenticationType = "LbcBackEndCookie", RedirectUri = postLoginRedirectUri, SignInAsAuthenticationType = "LbcBackEndCookie", ClientId = clientId, Caption = "BackOffice", Authority = authority, Scope = OpenIdConnectScope.OpenIdProfile, ResponseType = OpenIdConnectResponseType.CodeIdToken, RequireHttpsMetadata = false, // CallbackPath = PathString.FromUriComponent("/signin-oidc") , //CallbackPath = PathString.FromUriComponent("/umbraco/"), }; SetBackOfficeLoginProviderAdditionalOptions(adOptionsBackend, "editor"); NotificationAdOptions(adOptionsBackend, "", ""); adOptionsBackend.ForUmbracoBackOffice(style, icon); app.UseOpenIdConnectAuthentication(adOptionsBackend); } private static void NotificationAdOptions(OpenIdConnectAuthenticationOptions adOptions,string clientid, string tenantid ) { adOptions.Notifications = new OpenIdConnectAuthenticationNotifications() { MessageReceived = (context) => { Console.WriteLine("*** MessageReceived"); return Task.FromResult(0); }, SecurityTokenReceived = (context) => { Console.WriteLine("*** SecurityTokenReceived"); return Task.FromResult(0); }, AuthorizationCodeReceived = (context) => { Console.WriteLine("*** AuthorizationCodeReceived"); return Task.FromResult(0); }, SecurityTokenValidated = (context) => { try { var id = context.AuthenticationTicket.Identity; var nid = new ClaimsIdentity(id.AuthenticationType, ClaimTypes.GivenName, ClaimTypes.Role); nid.AddClaim(new Claim(ClaimTypes.Email, id.Name)); nid.AddClaim(id.FindFirst(ClaimTypes.NameIdentifier)); nid.AddClaim(id.FindFirst(ClaimTypes.GivenName)); nid.AddClaim(id.FindFirst(ClaimTypes.Name)); nid.AddClaim(id.FindFirst(ClaimTypes.Role)); nid.AddClaim(id.FindFirst("tenant_ctry")); context.AuthenticationTicket = new AuthenticationTicket(nid, context.AuthenticationTicket.Properties); } catch (Exception ex) { throw; } return Task.FromResult(0); } }; } }
Problem is SecurityTokenValidated getting called several times. I have validated code and token via Fiddler trace, I am getting claims and Id tokens from Azure AD.
Is there anything wrong with middle ware configuration or code above.
middleware in startup class is
private void ConfigureBackEndMiddleWare(IAppBuilder BackendApp) { var cookieOptions = new CookieAuthenticationOptions(); cookieOptions.CookieName = "LbcBackEndCookie"; cookieOptions.ExpireTimeSpan = TimeSpan.FromDays(10); cookieOptions.CookieSecure = CookieSecureOption.Never; cookieOptions.AuthenticationType = "LbcBackEndCookie"; cookieOptions.AuthenticationMode = AuthenticationMode.Passive; cookieOptions.CookieSecure = CookieSecureOption.Never; BackendApp.UseCookieAuthentication(cookieOptions, PipelineStage.Authenticate); BackendApp.UseExternalSignInCookie("LbcBackEndCookie"); BackendApp .UseUmbracoBackOfficeCookieAuthentication(UmbracoContextAccessor, RuntimeState, Services.UserService, GlobalSettings, UmbracoSettings.Security, PipelineStage.Authenticate) .UseUmbracoBackOfficeExternalCookieAuthentication(UmbracoContextAccessor, RuntimeState, GlobalSettings, PipelineStage.Authenticate) .UseUmbracoPreviewAuthentication(UmbracoContextAccessor, RuntimeState, GlobalSettings, UmbracoSettings.Security, PipelineStage.Authorize); BackendApp.ConfigureUserManagerForUmbracoBackOffice( Services, Mapper, UmbracoSettings.Content, GlobalSettings, global::Umbraco.Core.Security.MembershipProviderExtensions.GetUsersMembershipProvider().AsUmbracoMembershipProvider()); BackendApp.ConfigureBackOfficeAzureActiveDirectoryAuth(tenant, clientId, redirectUri, new Guid(tenant), "LbcBackEndCookie"); }
Umbraco backoffce is going into infinite loop after login.
Dear all,
