How does Asp Identity fit with umbraco 7+?
Could I introduce it and have a site utilising the public side with Identity leaving the back end as it currently is? If yes how does the inbuilt Members section work?
Hi Linx
If you want to use the ASP Identity with Umbraco then I would highly recomend that you take a look at the following package from Shannon
https://github.com/Shazwazza/UmbracoIdentity
Hope this helps,
/Dennis
How does Asp Identity fit with umbraco?
Hi Linx
Hope this helps,
/Dennis
