  • Sprite 18 posts 158 karma points
    Jun 04, 2021 @ 10:20
    Sprite
    Umbraco forms issue
    i have an issue with the umbraco forms (version 8.7.3)
    this version has recaptcha v3 built in. But when i try to use it i am getting the error that the score is incorrect (always)
    However i have found out what the problem is but i can't figure out a correct solution.
    The issue is that with certain cultures it goes correct, and with some cultures it is incorrect. This is because of the 0.5 score it needs to be.
    if i set the settings to nl_NL for instance i am getting the error that the score is not good enough. When i change the json of that form from 0.5 to 0,5 and then try again it works. However then it won't work with the en-US culture.
    So basically i can't get the recaptcha form to work on multilanguage websites that have a different culture set up.
    Can anyone help me out on how to solve this issue? So that it could work with both cultures regardless of a . or ,?
