  • Thomas 160 posts 335 karma points
    Jun 27, 2021 @ 21:11
    Thomas
    Examine v1.2.1 query problem
    Hi all. I have a news site based on umbraco 8.11.1 with Examine v1.0.6 and i am using the following code in order to query articles.
    // Get the external index with error checking
            if (!_examineManager.TryGetIndex(UmbracoIndexes.ExternalIndexName, out IIndex index))
                throw new InvalidOperationException($"No index found by name {UmbracoIndexes.ExternalIndexName}");
            try
                var searcher = index.GetSearcher();
                var criteria = searcher.CreateQuery(IndexTypes.Content);
                // Search Code to use with the ExternalIndex
                var examineQuery = criteria.Field("__NodeTypeAlias", "newsArticle");
                if (model.ParentId.HasValue)
                    examineQuery.And().ParentId(model.ParentId.Value);
                examineQuery.OrderByDescending(new SortableField[] { new SortableField("articleUpdateDate", SortType.Long), new SortableField("__NodeId", SortType.Int) });
    The value of the examine query is
    +__NodeTypeAlias:newsarticle
    if the parentID varialble does not have value and
    +__NodeTypeAlias:newsarticle +(parentID:[1063 TO 1063])
    if the parentID variable has a value.
    The results are great and works as expected.
    After upgrading umbraco to 8.14.0 which upgrades the Examine library to 1.2.0 unfortunately i am not getting any results. If a use the umbraco backend examine search interface i am getting results but from the code behind i am not getting anything.
    Any help please?
    Jun 27, 2021 @ 22:10
    Thomas
    Well after a lot of debugging on the following code
    try
                int pageSize = model.ItemsPerPage;
                int pageIndex = model.CurrentPage - 1;
                ISearchResults searchResult = examineQuery.Execute(maxResults: pageSize * (pageIndex + 1));
                IEnumerable<ISearchResult> pagedResults = searchResult.Skip(pageIndex * pageSize);
                int totalResults = Convert.ToInt32(searchResult.TotalItemCount);
                model.TotalItems = totalResults;
                model.TotalPages = (totalResults + model.ItemsPerPage - 1) / model.ItemsPerPage;
                if (pagedResults != null && pagedResults.Count() > 0)
                    model.Articles = GetArticlesFromSearch(pagedResults);
            catch (Exception e)
                _logger.Error(GetType(), "Search | Exception: {0} | Message: {1}", e.InnerException != null ? e.InnerException.ToString() : "", e.Message != null ? e.Message.ToString() : "");
    i found that i am getting value for the searchResult.TotalItemCount but i am not getting Results. Using Examine 1.0.6 i was getting the Results also.
